Old 10-22-2013, 03:30 PM   #1
CoryM
Drives: 2009 5-door, 5-speed
Thanks guys. Took it to work and now, of course, it is working fine. Capacitor it required to start the motor, and motor will turn if manually assisted. Do capacitors ever intermittently work? Took motor apart, it is brushless so not much to look at .
Old 10-22-2013, 03:36 PM   #2
Caps can dry-out and as they do they lose their capacitance. It may be that the pump starts fine with no load, but with a load the capacitor may not be doing its job to start the motor.
Old 10-22-2013, 10:28 PM   #3
CoryM
Drying out caps seems like a permanent thing, not a "works most of the time" thing. I'm just worried it's a bad section/transistor of the motor, and only doesn't work when stopped on that spot. It does, however, make the same sound with the cap unplugged as it did when it was in the machine and not working. I live alone so it's not like this dishwasher gets overused.... much to my girlfriends chagrin That makes me think the capacitor is more likely, rather than the motor. I'll see what I can get a cap for locally, and if cheap enough, throw it in. Arg. I don't mind spending $60 but hate wasting money. It's not worth paying anyone to test anything either.
Cheers.
Old 10-29-2013, 10:05 AM   #4
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I've had issues like this on our clothes dryer and a concrete tumbler.
Pleas note, these are not usual electrolyte capacitors with a conducting fliud inside!
Instead, it's some kind of oil.
The capacity loss is a result of inuslation failures between the aluminium sheets.
They are so thin that the short circuit burns away ("self healing"), but this always results in a capacity loss and one day the motor won't spin up anymore.
The ones I replaced smelled like having been fried in a pan as I opened them
I've replaced both with solid state foil capacitors and up to now they both work like a charm.
Capacity and voltage should match (voltage is the maximum allowable, so the value of the predecessor can of course be exceeded by the replacement capacitor), that's all, considering the flowing current is usually rather low.
dj92 is offline   Reply With Quote
Best place to place toyota motors emblem Ariel K Cosmetic Modifications (Exterior/Interior) 15 05-23-2012 01:11 PM
Tata Motors to introduce Air Car - Is it the next big thing? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 24 09-29-2010 11:42 AM
First Government Motors Car Built Kal-El Off-topic / Other Cars / Everything else Discussions 2 06-19-2009 06:24 AM
Motors in the doors Indianspringsaz In Car Entertainment + Electronics (audio / video / alarm) 1 07-14-2007 06:35 PM
Tesla Motors Roadster, 0-60= 4 seconds! Yaris Revenge Off-topic / Other Cars / Everything else Discussions 12 07-25-2006 08:56 PM
