Drives: Toyota Yaris Join Date: Jan 2010
Door latch removal
Hi - How do you remove the driver's door latch on my daughter's 2004 Yaris? The cable has broken between the inner door opener and the latch. I have removed the door panel, undone 3 screws and a bolt securing the latch. Now the latch is only attached by the outer door handle lift rod. How can I detach this from the door latch? Many Thanks Carl.
Drives: Yaris Join Date: Jan 2010
I have the same problem. only happened to me today if you have found the solution can you let me know.
Cheers |
![]() ![]() Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
Old thread resurrection !
Is this all I need to know if I want to replace the driver's door latch ? I know how to remove the inside panel... I will see what stuck me tomorrow when I will install it. Many thanks! |
Drives: Toyota Yaris, 2004, 2 doors Join Date: Oct 2013
Another resurrection, exactly the same problem! How do i find out the exact product code for the replacement cable? I want to make sure I get the right one for a 2004 Yaris, 2 door version.
There are a few variations for your French made Yaris. PM me your VIN and I can tell you exactly which one is used on your car.
04 EU yaris uses rods.
Correct - Rods for the locks, but still cables for the inside door handle (which is what I believe the OP is looking for).
You are right.. cable from the handle
| DIY for Steering Wheel/Airbag Removal? | MGargano | DIY / Maintenance / Service | 5 | 03-01-2019 02:21 AM |
| Paintless Dent Removal - Dent Magician | Chupacabra | General Yaris / Vitz Discussion | 3 | 01-27-2009 10:07 PM |
| Weight Savings - Removal, Reduction, Reminder.... | TRD_Yaris | Performance Modifications | 17 | 08-12-2006 02:07 PM |
