Old 11-07-2013, 07:09 PM   #1
bail_w
Drives: 2007 Toyota Yaris LB
Dam it! Airbag light of my 2007 yaris turned on...
Will try to get the code this weekend.
Edit: Error Codes: 51 & 43
bail_w is offline   Reply With Quote
Old 07-23-2014, 08:32 PM   #2
The 51 will be solved by changing the spiral cable (and I believe that if you go to the dealer they will replace it with a current one until the new ones become available).
The 43 is odd as that is related to the passenger airbag on/off indicator, and is completely unrelated to the spiral cable.
Old 07-24-2014, 03:30 PM   #3
07HBYaris
07HBYaris's Avatar
Drives: Yaris HB 2007
airbag light update.
Scott, thanks for the jumper trick.
To my relief, my car was spitting code 51 only.
I'm @ toyota right now getting a current one installed while the recall is remedied and then I'll be back for recall replacement.
The service rep. Said that if the srs light is on, the whole srs system is down. So drive with that in mind for all those that are affected.
no a/c + traffic =
07HBYaris is offline   Reply With Quote
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
