Old 11-12-2013, 12:05 AM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
71+ mph in the 1/4 is good for a 1300cc auto!
As far as faster, if the 1.216 is your reaction time, you could try anticipating the green light to reduce that time. Even if you could cut that time in half, 6 tenths of a second is a lot of time to cut off your quarter without needing your car to be any faster than it is right now.
Removing any excess weight for your drag runs, like the spare tire and jack, would help. On a little light car, any removed weight will make it faster. You could also pump up your rear tires to 45 psi to lower their rolling resistance. Also run with all of your windows up and vents closed to lower the wind resistance. All these little refinements can really add up.
Greg
Old 11-12-2013, 07:19 AM   #2
Ryze268
Ryze268's Avatar
Drives: 2002 JDM Vitz 1.3
Greg
Thanks a lot for the kind words, I'll give all this a try and let you know of the improvements
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete
Follow me on Instagram:
instagram.com/itzkingjustin
Ryze268 is offline   Reply With Quote
