There is no EGR, so when your mechanic tells you it's ok and charges you, he's ripping you off.
Yup you are correct!...I'll take back what I said earlier...even the part about the rings...
![]() Drives: '08 Manual Yaris Sedan Join Date: Mar 2013
#4 | |
Piston slap is all you're hearing. It's normal on a cold engine. As the cylinder bore wears, piston to cylinder wall clearance increases and allows the piston to rattle back and forth slightly causing the knocking sound. Nearly every engine will eventually do it. You just need to take it really easy on it until it has had a chance to warm up and expand to close the gap. |
| Cleaning throttle body | ToTo | Performance Modifications | 18 | 07-27-2011 05:20 PM |
| 1ZZ-FE throttle body | crxgames | Items for Sale by private party | 1 | 04-27-2009 05:19 PM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
| Toyota Throttle Body Spacer: the Best Fuel-Saving Device | davidmills | Performance Modifications | 1 | 07-01-2007 11:38 PM |
| Carbon offsetting with TerraPass | BailOut | General Yaris / Vitz Discussion | 14 | 05-28-2007 12:29 AM |
