Old 11-12-2013, 10:47 PM   #1
Sedan
Drives: '08 Manual Yaris Sedan
Originally Posted by Bluevitz-rs View Post
There is no EGR, so when your mechanic tells you it's ok and charges you, he's ripping you off.
Thanks.
Is the EGR only available in the diesel varient?
And guys, is there a way to test weather VVTI is working properly?
Sedan is offline   Reply With Quote
Old 11-13-2013, 07:35 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by Sedan View Post
Thanks.
There is no EGR because of VVT-i. Only way to test is with a Techstream Tool from Toyota.
Piston slap is all you're hearing. It's normal on a cold engine. As the cylinder bore wears, piston to cylinder wall clearance increases and allows the piston to rattle back and forth slightly causing the knocking sound. Nearly every engine will eventually do it. You just need to take it really easy on it until it has had a chance to warm up and expand to close the gap.
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
Carbon offsetting with TerraPass BailOut General Yaris / Vitz Discussion 14 05-28-2007 12:29 AM
