Old 11-17-2013, 11:46 PM   #1
redroxs
Drives: Toyota Yaris
hey all - new to this forum and have a similar problem. My front passenger door of my Yaris does not latch when i lock them with my power lock on my key. I have to always tell the passenger to manually lock the door as they exit. Kind of embarrassing. However, all other doors lock with my power locks. Even when I'm in the car and we are driving and I try to lock all doors with from the driver side, my passenger side door does not lock. I'm trying to figure out what the actual problem is and how to resolve it without spending tons of dollars at the dealership.
Many thanks in advance!
redroxs is offline   Reply With Quote
Old 11-18-2013, 06:11 AM   #2
It could be that the lock actuator is bad or the wiring to it is damaged, or the mechanical cable between the lock lever and the actuator is bound. The first thing to do would be to take off the door panel on that side and get a look at the wiring and the cable. If that all look OK, you would then want to unplug the connector from the actuator and measure the voltage on the connector while power locking the doors. If you see the pulse on that connector then you will know for sure that the actuator is bad. The actuator is part of the door lock/latch assembly, so you would need to replace that entire assembly.
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 01:38 PM
Question about Power Locks absolution8 General Yaris / Vitz Discussion 3 05-30-2011 06:20 AM
Power windows and locks on a 2009 3dr. chilly79 DIY / Maintenance / Service 8 12-15-2010 12:55 PM
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
