Old 11-19-2013, 08:01 PM   #1
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Originally Posted by IllusionX View Post
speaking of disconnecting the battery... i often hit the negative pole of the battery with my tool when undoing the positive pole.
I should use a shorter wrench
Are you bragging or complaining?
Seriously, though, always remove the positive battery connection first and replace it last. And yes, you should use a shorter wrench.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 11-19-2013, 08:32 PM   #2
Actually just the opposite - Always disconnect the negative terminal first and connect the negative last. The reason for this is that the chassis is grounded, so if while wrenching the positive terminal you touch anything metal you will short the positive to ground and make a heck of a spark or do worse that that.
When jumping a car you do just the opposite - Connect positive first and disconnect it last.
