Old 12-04-2013, 02:13 PM   #1
bubu
Drives: Yarsis 2007
The rear fog is fed by the 7.5A RR FOG fuse.
The indicator is driven directly off the feed to the bulb, so if it is not on neither will the light be.
the indicator in the dash is feed directly to what goes to the bulb ?
related to the relay ... I did not find a diagram to check whichone should be ...
bubu is offline   Reply With Quote
Old 12-04-2013, 02:25 PM   #2
Yes. The indicator is fed by the power to the bulb.
If you look at the under dash fuse panel you will see many connectors on the face of it and some relays at the bottom. Attached to the right side of it there is one connector and one or two relay sockets below the connector. If your car uses the rear fog relay there will be two and the bottom one will be the rear fog relay.
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
