Old 12-04-2013, 02:25 PM   #1
vinojcosta
Drives: Yaris 2008
ABS light problem
Yeah I have abs in my car, the doesn't come on even the first time and Once I tried to break hard in a gravel road still doesn't work.
vinojcosta is offline   Reply With Quote
Old 12-04-2013, 02:31 PM   #2
Verify that you really have ABS by looking for the ABS pump an ECU below the brake master cylinder. If it is there there will be short metal pipes that connect it to the master cylinder and it will have a large connector (about 3 inches by 1.5 inches) plugged into it.
The instrument cluster gets the information over the CAN bus from the ABS ECU, so even if the ABS ECU was present and bad the cluster would still light the light for a second when the ignition is switched on, and if it doesn't send messages to the cluster once the car is running it will keep the ABS light on.
CONSUMER REPORTS : March issue : 2010 YARIS sedan Hershey General Yaris / Vitz Discussion 41 02-18-2011 03:41 AM
Difference between 2007 and 2008 Yaris? wihed General Yaris / Vitz Discussion 5 01-02-2011 08:20 PM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 09:46 AM
