Old 12-06-2013, 09:53 PM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Do those Unichip able to over-write the engine ecu fuel map permanently?
In the past from what i heard is that after the tuning, you will be able to feel the gain on power and torque. After couple of weeks, the engine will re-learn and adjust the fuel map to over-write the Unichip map and therefore the power & torque will be back to square/stock one.
Is that true?
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 12-06-2013, 10:06 PM   #2
Is that true?
It simply is a piggyback that modifies the crank signal (to adjust timing) and MAF signal (to adjust fuel) to the ECM. The ECM will still see the output changes via the AFR sensor and will eventually trim out the changes.
Old 12-06-2013, 11:05 PM   #3
Chuckie
Drives: 2011 Yaris Hatchback
^^^ Its I widely used chip here on a lot of different makes and models. There have been no issues of the settings returning to stock while the chip is installed and tuned. As soon as the chip is installed on to the ECU and tuned, the ECU will continue to take orders from it. Once it is removed, everything goes back to stock.
Chuckie is offline   Reply With Quote
Old 12-06-2013, 11:13 PM   #4
Chuckie
Changes are permanent as long chip is installed..
Old 12-06-2013, 11:08 PM   #5
Chuckie
Is that true?
As long as it is installed, it overwrites whichever ECU setting. The only time it returns to stock is if it is tuned to stock or removed..
Old 12-06-2013, 11:37 PM   #6
Chuckie
Is that true?
Thats kinda like a myth thats been proven wrong for years here. Its not too smart for a company to design a chip that will be simply overridden by AF sensors. What would be the point then for 225 USD chip?
Old 12-06-2013, 11:43 PM   #7
Your Asian market cars have different ECMs than the US market ones.
The US market ones aggressively maintain stoich (14.7 AFR) to comply with our emissions standards. There are many devices that can be purchased for $50 to $500 that promise power and economy gains, but all that I have seen tested have failed to deliver.
$225 would be far better spent on a used AEM F/IC, which at least has the ability to modify the output of the AFR sensor to fool the ECM into thinking that it is running at stoich, while the actual AFR is adjusted.
Old 12-07-2013, 06:15 AM   #8
Chuckie
Oh I see../ Maybe the Dastek unit is capable of ' modifying the output of the AFR sensor '; or it may have some function built in that would achieve the same result. The shop that deals them here has been using them on everything from SUV's, pickups, European cars, Japanese cars, to Mustangs. They all maintain the tuned settings unless removed or retuned. Gains in power and mileage are retained.
Old 12-07-2013, 06:23 AM   #9
Chuckie
^^^ Oh sorry, I forgot about the stock AFR setting you mentioned on U.S ECMs due to emission standards. That would make a difference. Unless there is a function in the Dastek unit to override even that if at all possible. The company stresses the fact that its a lot more than a chip; like an onboard computer or an ECM/ECU in itself in ways.
Old 12-07-2013, 06:38 AM   #10
Chuckie
^^ Im pretty sure the Chevys and Fords being sold here are to U.S specs. (not 100% sure) - no problems retaining gains after tuning on them here.
I think one of the main problems of using this unit in the United States is finding a tuner as CaliYaris mentioned. Here, there is only one shop that is trained, capable and *licensed to do the Dastek units.
Personal review, european version kavaron Third Gen Yaris General Discussion 1 10-20-2011 08:08 PM
Interest in a unichip ecu tune ????? blacksandiegovitz Performance Modifications 25 07-12-2009 12:46 PM
FS:Dastek Unichip +Q Katana Items for Sale by private party 1 11-28-2006 04:24 PM
