Old 12-06-2013, 10:06 PM   #1
Originally Posted by evo165 View Post
Do those Unichip able to over-write the engine ecu fuel map permanently?
In the past from what i heard is that after the tuning, you will be able to feel the gain on power and torque. After couple of weeks, the engine will re-learn and adjust the fuel map to over-write the Unichip map and therefore the power & torque will be back to square/stock one.
Is that true?
It simply is a piggyback that modifies the crank signal (to adjust timing) and MAF signal (to adjust fuel) to the ECM. The ECM will still see the output changes via the AFR sensor and will eventually trim out the changes.
Old 12-06-2013, 11:05 PM   #2
Chuckie
Drives: 2011 Yaris Hatchback
^^^ Its I widely used chip here on a lot of different makes and models. There have been no issues of the settings returning to stock while the chip is installed and tuned. As soon as the chip is installed on to the ECU and tuned, the ECU will continue to take orders from it. Once it is removed, everything goes back to stock.
Chuckie is offline   Reply With Quote
Old 12-06-2013, 11:13 PM   #3
Chuckie
Changes are permanent as long chip is installed..
Personal review, european version kavaron Third Gen Yaris General Discussion 1 10-20-2011 08:08 PM
Interest in a unichip ecu tune ????? blacksandiegovitz Performance Modifications 25 07-12-2009 12:46 PM
FS:Dastek Unichip +Q Katana Items for Sale by private party 1 11-28-2006 04:24 PM
