Old 12-11-2013, 09:04 AM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Tried 15x7 Rpf1, cannot clear my 285mm rotor. Therefore I opt for the 16". I have tried 17" wheel with 205. It handle great but I loss the acceleration speed. :(
Now on 15x6.5, love the acceleration speed now and lighter wheel give much better braking performance. Not sure is the 16 rpf1 rim at 13.5lbs light enough for my acceleration craving.
Currently my type-F is at 9.5lbs. I love current set up and I just want a little better road handling.
Btw I am not tracking/auto crossing. Just love some street sprinting. ;)
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 12-11-2013, 12:01 PM   #2
Jason@SportsCar
I don't know what brand/model of tire you plan to use but in almost every case the 15x7-205 setup is going to beat 16x7-205. The 15" package will be lighter (both the wheel and tire in most cases), and the diameter (effective gear ratio) will be better - most 205-50-15"s are 23", while a 205-50-16 is around 24" and a 205-45-16 is around 23.2". Its all little stuff, but it adds up.
I would go with the RPF1 and add a spacer/stud kit in the front. Its not much work and should solve your problem. You don't even have to remove the front hubs to swap out the studs, there is an indent in the knuckle that lets you slip them by. http://shop.microimageonline.com/Ich...s-SC-58805.htm
The easy button to better performance would just be a tire change with your current wheels. The top 15" street tire in autox for about the last five years has been the 195-50-15 Toyo R1R. It seems small, but it works like a champ on light FWD cars, no other 15" tire has won a ST class Solo championship in years.
Old 12-11-2013, 09:04 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
This. It's is on my dream list for the coming season. After the helical diff, of course. If you just want stupids amounts of acceleration, smaller diameter is almost as good as lighter. There's some physics involved in it, but I'll skip it since most people start throwing things at me when I start in on it.
I ended up with the Tire Rack house brand 15x7 this past summer, about 13 lbs per wheel. I ran the new BFG Rival in 205/50R15 but had serious acceleration loss compared to my street setup (15x5.5 11 lb Mini Cooper wheels w/205/50R15 DZ101's).
Old 12-16-2013, 07:46 AM   #4
Lars
Yaris beginner
Drives: Yaris XP9F
The physics are simple actually!
Two objects of the same weight and "shape/size", the rotational inertia will be lower in the one where the weight is most concentrated close to the rotation center.
So, even if you have two wheels of the same total diameter, same weight, acceleration/braking will be better with the wheels that have a smaller rim, as the weight is closer to the rotation axis (or the biggest part of the weight).
The trade off, I would say, is tire deformation on hard cornering, but in light cars like ours I would say that trade off is not as critical as on big heavy porsches/bmws...
Lars is offline   Reply With Quote
17x7 Enkei RPF1 with 43mm offset wheels with 205/45ZR17 tires with DF210s, OK? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 11-01-2012 03:29 PM
enkei vs 5zigen for yaris sedan 07 gudboi182 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 02-28-2012 01:27 AM
Feedback requested: Enkei RPF1 & Yokohama S.drive Iggy888 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 08-14-2010 06:14 PM
Enkei Racing RPF1 phenoyz Willing to Buy by private party 6 06-26-2009 01:40 PM
