#1 | |
I would go with the RPF1 and add a spacer/stud kit in the front. Its not much work and should solve your problem. You don't even have to remove the front hubs to swap out the studs, there is an indent in the knuckle that lets you slip them by. http://shop.microimageonline.com/Ich...s-SC-58805.htm The easy button to better performance would just be a tire change with your current wheels. The top 15" street tire in autox for about the last five years has been the 195-50-15 Toyo R1R. It seems small, but it works like a champ on light FWD cars, no other 15" tire has won a ST class Solo championship in years.
#2 | |
2ZR swap. DO IT! Ask how!
I ended up with the Tire Rack house brand 15x7 this past summer, about 13 lbs per wheel. I ran the new BFG Rival in 205/50R15 but had serious acceleration loss compared to my street setup (15x5.5 11 lb Mini Cooper wheels w/205/50R15 DZ101's). |
#3 | |
Yaris beginner
Two objects of the same weight and "shape/size", the rotational inertia will be lower in the one where the weight is most concentrated close to the rotation center. So, even if you have two wheels of the same total diameter, same weight, acceleration/braking will be better with the wheels that have a smaller rim, as the weight is closer to the rotation axis (or the biggest part of the weight). The trade off, I would say, is tire deformation on hard cornering, but in light cars like ours I would say that trade off is not as critical as on big heavy porsches/bmws... |
| 17x7 Enkei RPF1 with 43mm offset wheels with 205/45ZR17 tires with DF210s, OK? | CtrlAltDefeat | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 11-01-2012 03:29 PM |
| enkei vs 5zigen for yaris sedan 07 | gudboi182 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 02-28-2012 01:27 AM |
| Feedback requested: Enkei RPF1 & Yokohama S.drive | Iggy888 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 08-14-2010 06:14 PM |
| Rim Weights | bosbik | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 16 | 11-14-2009 06:42 PM |
| Enkei Racing RPF1 | phenoyz | Willing to Buy by private party | 6 | 06-26-2009 01:40 PM |
