Most likely the coolant temperature sensor is failing. You can easily tell if you can find someone with a scangauge type device, which will let you display the temp that the ECM is seeing from the sensor.
| Check Engine Light P0455, P0441, P0456 | RedStickHam | DIY / Maintenance / Service | 8 | 12-01-2013 01:41 PM |
| Maintenence Required light won't turn off... | tooter | Third Gen Yaris General Discussion | 7 | 04-11-2013 10:31 AM |
| Engine brake with cold engine and high rotation speed | josellwoll | General Yaris / Vitz Discussion | 3 | 11-06-2012 07:52 PM |
| Original tail light without rear fog light for Yaris 3dr 2009-2011 | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 9 | 08-07-2012 05:27 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
