Old 12-17-2013, 04:11 PM   #1
thetut
Drives: 2007 4dr sedan
Lars,
I noticed a few weeks ago that my Yaris would only start if I held the key in the start position when it was cold. The cranking also felt slower than usual.
I changed the battery and now it functions as designed.
Your battery may be getting weak.
thetut is offline   Reply With Quote
Old 12-18-2013, 04:56 AM   #2
Lars
Yaris beginner
Drives: Yaris XP9F
Originally Posted by thetut View Post
Lars,
Hi thetut,
Good point. Was your start/stop not working also before you switched your battery?
When I stop at traffic lights or whatever the indicator "ECO OFF" simply turns on and it doesn't shut off the engine (on low temps, like I mentioned). I guess it can make sense that it is a battery problem as batteries "lose juice" when cold, I guess?
Thanks!
Lars is offline   Reply With Quote
Old 12-18-2013, 01:09 PM   #3
thetut
Hi Lars,
I don't have the ECO function so I guess we are talking about separate problems. I thought you were talking about the feature that allows the starter to continue to crank the engine without holding the key in the start position.
I would still have your battery tested if I were you.
Cold weather and batteries cause strange problems.
Old 12-20-2013, 03:19 AM   #4
Lars
Yaris beginner
Drives: Yaris XP9F
Hi Lars,
Hi Tut!
Oh interesting... I would have assumed that all 1NR-FE would have the ECO thingy... so maybe it is normal that on low temps ECO doesn't kick in?
Maybe I'll open a new thread for that... but I'm not really worried, I can ask at the next inspection.
Thanks!
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Toyota Yaris Engine Map wariss Performance Modifications 5 03-15-2009 12:21 PM
