Could it be the front wheel bearings (if it's not the above) ? The scenario he describes sounds similar to what I was hearing at about 110k. I was told the front wheel bearings needed to be replaced. I had them replaced, and the sound disappeared.
Wheel bearing are a possibility as well. Although with them the noise typically doesn't start all of the sudden.
Okay I'll take a look. I've been driving in them like this since the end of November. No problems so far. My car has never had a misalignment issue. And my alignment so far is still good. I hope it's not a wheel bearing. Do I need to check all four corners or just the front where the noise is coming from. In march I had planned on buying new tires after I get my tax refund. So if I need new tires it has to wait till then.
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| 2011 NISSAN JUKE!! 4 dr hatch awd turbo. | marcus | Off-topic / Other Cars / Everything else Discussions | 35 | 09-12-2010 12:18 AM |
| My other sound, suspension? | N9QGS | DIY / Maintenance / Service | 2 | 10-19-2009 02:26 AM |
| Humming noise when turning the steering wheel!! Help?? | mhkritzinger | DIY / Maintenance / Service | 7 | 09-28-2009 08:27 AM |
| Chirping, squeeking sound | ToTo | Performance Modifications | 7 | 04-21-2007 04:29 AM |
