Old 12-20-2013, 11:56 AM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I can't imagine their pulling the data from a front o2 sensor, or a thread in Wideband sensor. Most dyno shops use a wire sensor that sticks into the back of the tailpipe.
Given the rest of the engine is fairly stock, I'm gonna go with there was an exhaust leak at the axle back joint. Exhaust leaks don't hurt performance by affecting AFR they hurt performance because an exhaust leak creates turbulent air flow which restricts flow in the tube. Even small exhaust leaks can cause huge losses of power.
Old 12-20-2013, 12:38 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Excellent point. I believe you hit the bullseye.
We did use a tailpipe sniffer for the A/F reading, and it was likely indicating a problem that did not actually exist, because there were no other negative symptoms like rough idle, thrown codes, bogging down, etc. The engine ran good, just not as good as with the MagnaFlow exhaust.
Greg
My exhaust experiment! fuji Performance Modifications 12 05-20-2009 05:58 AM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
