Drives: Yaris 2014 HatchBack Join Date: Dec 2013
Spacers Adapters 4x100 to 4x108 1"
I bought 4 rims 17" 7.5 for my Yaris 2014 but unfortunately are 4x108 and the Yaris is 4x100. I searching solutions and 1 solution is buying spacers 1 inch that convert the bolt pattern. My doubt is: If I install the rim with the spacer , don't make me any problem? The wheel don't touch the fenders or something? Please I need help.
Form>Function
what is the offset of those wheels?
even without knowing what the offset is im pretty sure you're going to rub. The offset is probably around +25-45 and that would mean after the spacer youre sitting effectively at 17x7.5 +0-20. if you're running 195 or 205 you will not have enough stretch to clear the fenders without modification. |
Do some measuring. A 1" spacer is going to push your wheels out quite a bit.
| Tags |
| 4x108, adapters, rims, spacers, wheels |
| FS in FL: Spacers, 32MM 4x100 | DJ_SpaRky | Items for Sale by private party | 8 | 07-27-2011 02:27 PM |
| 4x100 --> 5x130 adapters | sasquatch | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 01-30-2010 08:46 AM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 07:10 PM |
| 4x100 to 5x112 adapters???? | contraband831 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 02-12-2009 05:58 PM |
