Old 12-24-2013, 12:31 PM   #1
racefear
Drives: yaris 2006
Need to find my last wire, please help : door trigger input pin wire(wich monitors all the door)
Connector 4A ??? Wich pin ?
Door triggers (negative input when door is open):
FL-red wire 4A-21, FR-light blue wire 4A-24, RL-green wire 4A-5, RR-light blue wire 4A-20, Trunk/Hatch- Sky blue wire 4A-7
Tanks
racefear is offline   Reply With Quote
Old 12-27-2013, 11:43 AM   #2
Tanks
The Yaris does not have a single door trigger monitor for all doors.
You could either use the pink wire for the dome, or connect a diode to each door wire with the white stripe on the diode pointing away from the wires and connect all of the white stripe ends together and to the door trigger input.
Old 01-04-2014, 12:26 PM   #3
racefear
Drives: yaris 2006
ok tanks, for the pink dome wire, did you mean the pin 4 on the 4a connector ?
I don't have the best wirring diagram sheet...
Tanks
Old 01-04-2014, 01:00 PM   #4
Tanks
No. The pink one in 4K (the upper left connector in this picture):
Old 01-27-2014, 03:33 PM   #5
racefear
Drives: yaris 2006
Hello all
A neutral safety switch must be install on a manual yaris, optional ? or the sequence of steps to be performed before exiting the car is ok...
What are the other step to do for the manual tranny like put the starter wire of the 'module' to the black wire of the clutch that is not show on the
Yaris 2006+ Remote Start Wiring Guide.pdf ??
In your Yaris 2006+ Remote Start Wiring Guide.pdf, I think the wire color you said for Doors Unlock (-pulse) is not green pin 8 but orange pin 6.
I have a toyota door lock key without bypass. Need to wire somethings for the FACTORY ALARM ?
Almost done but the car don't start after the ready mode procedures !
Tanks
Old 01-27-2014, 03:58 PM   #6
Hello all
Tanks
A neutral safety switch is a difficult thing to create for a vehicle that does not have one. If you have a remote starter that is designed for use with a manual, and it has one of those arming procedures, then that is fine. If you have one that only has the neutral safety switch input, then you really should figure out a way to add one.
On a manual you would need a bypass for the clutch switch. You would need to feed +12 volts to the black wire to bypass the clutch switch.
The wire that I show for the - unlock is correct, as that is what I have used on quite a few installations. If you use the one that you mentioned it confuses the body ECU and if you use the inside lock switch, once you get out of the car the key fob will not lock the doors.
The - unlock green wire in pin 8 is also the one that will disarm the factory alarm, as the theft deterrent ECU sees it as someone unlocking the door with the key.
Old 01-30-2014, 03:04 PM   #7
racefear
Drives: yaris 2006
Is this the good connection for the bypass ??
All connection checked and good(Pro Start model), why that does'nt work ?
Manual tranny yaris 2006 with toyota key door lock without bypass module
- Ignition = green, pin 1
- +12 V 25A = yellow, pin 4
- Accessories = blanc, pin 2
- Starter(purple) = black starter wires on the ignition switch connector, pin7 Relay not necessary after test
- 5e Relais = ignition 2 = pink, pin 6
- +12 V 15A = gray, pin 5
____________
- Ground - = chassis ground
- Tach = data link connector = lt green, pin 9
- Hood Switch - = 'In Box'
- Brake Switch + = green, pin1
- Parking Light + = green, pin 29
______
- Horn - = black, pin 8
_______
- Neg Door Input - = Dome light, pin 2 Change to door switch(red & blue 'floor wire') wire does not work on Dome for me
- Parking Brakes Input - = lt green, pin 11
- Unlock - = brown, pin 5
- Lock - = Green, pin 8
Wiring Shematic CT-3271
the car don't start after the ready mode procedures ! Work good now, post UPDATED
Tanks
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
