Old 12-25-2013, 04:46 PM   #9
yaris9876
Drives: yaris hatch 07 640K original m
I assume you had to dis assemble and remove the entire front suspension??
about the AC..you had to remove that smaller radiator??? It looks like you can just detach the hoses
from the AC and its free of the motor...??
There is 1 motor mount on the passenger side..is the other mount the trans mount under on the other side??
I assume its much better to drop it than raise it,no??
If you went to a indy shop locally and hired them to do the whole thing,what do you think they would charge??
Anyone know of a shop that would just help partially anywhere in the SE USA??
btw do these look like real injectors to you??? 4 for 100$
http://www.ebay.com/itm/New-Denso-23...p2054897.l4276
about the water damaged engine...it was probably one of the hurricane Sandy flooders..there was thousands of them that got written off....you can run the VIN to check on them...most of them
would be in the NE but I imagine they spread them out among the parts yards a bit to get rid of them
all.
yaris9876 is offline   Reply With Quote
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Boost Gets U Laid eh? Count me In yaris2010RS Forced Induction Forum 128 02-02-2013 04:57 PM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
