![]() Drives: 2009 Yaris sedan black Join Date: Sep 2011
Debris in heater box, water under dashboard
Hi all,
2009 Toyota Yaris sedan, 76000 miles - During the summer I began to get a water leak under the passenger side dash when running A/C, sloshing water sound when making turns. Turned out there was a build up of debris (leaves, pine needles) in the heater box. Pinching, blowing out drainage tube no help. Had to have dashboard pulled and box cleaned out ($1000 mostly labor) - not covered by warranty or considered a defect - of course. Ive heard that Toyota is aware of the problem and there is a replacement cowl (under windshield wiper?) designed to prevent debris from getting into engine compartment/heater box but can't get any information on this... Has anyone else heard about a replacement cowl? Any ideas on who to contact - no response from Toyota yet. Thanks Last edited by tenchsama; 12-28-2013 at 11:33 AM. Reason: tags |
#2 | |
![]() Drives: 2013 Yaris HB Join Date: Dec 2013
I had the same problem when I owned my first Yaris 2007, took it to the dealer since it was still under warranty, they opened the blower box and emptied a ton of leaves stuck inside, also there was a clear rubber hose under the passenger side firewall that is suppose to drain this it, also gets plugged up. I don't think I was the first one with that problem.
The fix that I never got around to is put some sort of a screen cover over or under the windshield cowl intake, right under the wipers. I now have a 2013 Yaris, guess what it already has a screen cover under the cowl, so I hope this will prevent that problem. |
| Tags |
| heater, water leak |
| Dual 8’’ Cargo Floor Sub Box Build | Ataristyle | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 03-23-2016 01:27 AM |
| heater not working water coolant level drops | Mike Hancock | DIY / Maintenance / Service | 4 | 11-03-2011 02:14 PM |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 03:45 PM |
| Sub Box Desgin | talnlnky | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 08-23-2009 01:45 AM |
