Old 12-30-2013, 08:05 AM   #1
toyota86
Drives: Toyota 86 GTS
wow
Hi CTscot
I really like your post. Could you help me do the same thing but with a Toyota 86?
Here is the wiring diagram http://www.ft86club.com/files/BRZwiringi.pdf
I had a look at the Yaris diagram and it is similar but would really like some help.
Thank you!
toyota86 is offline   Reply With Quote
Old 12-30-2013, 08:44 AM   #2
Originally Posted by toyota86 View Post
Hi CTscot
Thank you!
The 86 is very different. The Body ECU has control over the lights.
You could try grounding the white wire in pin 20 of the headlight switch. If that works for making the headlights come on with the car off, then you would connect one contact terminal (30) of the relay to that wire and the other (87) to ground.
You would then connect pin 17 of body ECU connector D5 to the relay coil terminal 85 and terminal 86 of the relay coil to the dome light positive wire (it doesn't look like there is a simple connector for grabbing that wire, so you would have to find one of the orange or light green wires on page 184/185.)
Car doors are not self-locking when left unlocked fainty_girl General Yaris / Vitz Discussion 27 03-14-2011 09:12 AM
