Old 01-01-2014, 12:42 AM   #1
Originally Posted by mtshum View Post
Thanks, CTScott, do I need to remove the passenger seat to remove the second O2 sensor?
No. It comes through the floor right under the center of the dash. You will probably have to pull the AC controls to get to it.
Old 01-02-2014, 10:07 PM   #2
mtshum
mtshum's Avatar
Drives: Echo RS
Hi CTScott,
My check engine light was off this two day, do I still need to change the rear O2 sensor?
also, my car is only 77,000km. is it too early for the sensor to be failed?
Thanks
mtshum is offline   Reply With Quote
Old 01-02-2014, 10:58 PM   #3
Hi CTScott,
Thanks
You could wait and see if the code comes back. 77k Km does seem early, but there are a few things, including bad fuel that could foul one prematurely.
Old 02-01-2014, 12:32 PM   #4
mtshum
mtshum's Avatar
Drives: Echo RS
An update:
The code came back again, so finally replaced the second O2 sensor.
Just discover the left cv boot cracked, need to replace too.. ~~
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
Check Engine Light P0455, P0441, P0456 RedStickHam DIY / Maintenance / Service 8 12-01-2013 12:41 PM
ODB2 Check engine code reader Arkhangel Performance Modifications 11 02-25-2009 04:13 AM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
