![]() Drives: yaris 2006 Join Date: Nov 2013
ok tanks, for the pink dome wire, did you mean the pin 4 on the 4a connector ?
I don't have the best wirring diagram sheet... ![]() Tanks |
#2 | |
Hello all
A neutral safety switch must be install on a manual yaris, optional ? or the sequence of steps to be performed before exiting the car is ok... What are the other step to do for the manual tranny like put the starter wire of the 'module' to the black wire of the clutch that is not show on the Yaris 2006+ Remote Start Wiring Guide.pdf ?? In your Yaris 2006+ Remote Start Wiring Guide.pdf, I think the wire color you said for Doors Unlock (-pulse) is not green pin 8 but orange pin 6. I have a toyota door lock key without bypass. Need to wire somethings for the FACTORY ALARM ? Almost done but the car don't start after the ready mode procedures ! ![]() Tanks |
#4 | |
On a manual you would need a bypass for the clutch switch. You would need to feed +12 volts to the black wire to bypass the clutch switch. The wire that I show for the - unlock is correct, as that is what I have used on quite a few installations. If you use the one that you mentioned it confuses the body ECU and if you use the inside lock switch, once you get out of the car the key fob will not lock the doors. The - unlock green wire in pin 8 is also the one that will disarm the factory alarm, as the theft deterrent ECU sees it as someone unlocking the door with the key.
Is this the good connection for the bypass ??
![]() All connection checked and good(Pro Start model), why that does'nt work ? ![]() Manual tranny yaris 2006 with toyota key door lock without bypass module - Ignition = green, pin 1 - +12 V 25A = yellow, pin 4 - Accessories = blanc, pin 2 - Starter(purple) = black starter wires on the ignition switch connector, pin7 Relay not necessary after test - 5e Relais = ignition 2 = pink, pin 6 - +12 V 15A = gray, pin 5 ____________ - Ground - = chassis ground - Tach = data link connector = lt green, pin 9 - Hood Switch - = 'In Box' - Brake Switch + = green, pin1 - Parking Light + = green, pin 29 ______ - Horn - = black, pin 8 _______ - Neg Door Input - = Dome light, pin 2 Change to door switch(red & blue 'floor wire') wire does not work on Dome for me - Parking Brakes Input - = lt green, pin 11 - Unlock - = brown, pin 5 - Lock - = Green, pin 8 Wiring Shematic CT-3271 the car don't start after the ready mode procedures ! Work good now, post UPDATED Tanks Last edited by racefear; 02-13-2014 at 02:01 PM. |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
