Old 01-06-2014, 12:37 PM   #1
xiaoya
Drives: 2008 Yaris
Thanks for the prompt reply. I will give it a check at noon when it is not freezing cold outside. It is -34 C, and -50 C with windchill in Winnipeg.
I just used OBDII scanner and found no error code but the airbag warning light is solid on in the cluster panel.
xiaoya is offline   Reply With Quote
Old 01-06-2014, 12:44 PM   #2
OBDII can only read engine codes. You would need a Toyota specific scanner to read the SRS codes.
Old 01-07-2014, 09:53 AM   #3
xiaoya
Drives: 2008 Yaris
Thank you CTScott! The problem is gone.
When I check the two connectors on the passenger occupancy classification ECU (underneath the Passenger seat), the bigger was a tiny bit of loose. When I push it in a little bit I hear a click sound. Then the problem solved.
Thanks for the accurate diagnosis and prompt advices!
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 04:39 PM
Seat belt reminder warning Beep Jord DIY / Maintenance / Service 28 04-09-2009 08:37 AM
