#1 | |
![]() Drives: 2009 Yaris Sedan 4D Join Date: Jan 2014
#2 | |
![]() ![]() ![]() Drives: No more Yaris Join Date: Dec 2013
It's a common thing to do on a damp, chilly day. A/C to dry the air, the heater core to warm you up. |
#3 | |
The AC condensate drain hose goes through the floor at the top left of the passenger side foot well. If you pull the carpet back in that corner you will see the black hose that goes through the floor via a molded on grommet. You can pull that hose up and (with a pan under it to catch what comes out) you can run something flexible up into it to clear any debris that is blocking it. While you are doing that, open the glove box, squeeze the rear corners towards the center and remove the glove box. To the left, behind it, is the rectangular slot for the air filter. Pop the cover and see if one is installed. If not, grab yourself one at an auto parts store. No having one installed leads to stuff blocking the drain as well as eventual swampy stink from the AC.
| Tags |
| ice inside 2009 |
| Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c | Yar Is Word | Third Gen Yaris General Discussion | 27 | 09-06-2012 11:37 PM |
