Old 01-10-2014, 03:46 PM   #1
It may be the antenna coming loose or it may be that the condenser for the radio has gone bad. The condenser is a capacitor that is mounted in a black plastic box and is mounted under the C pillar cover on the driver's side.
To start with, to check the antenna, simply pull the vertical trim pieces off on the sides of the radio (just gen your fingers under the bottom). Once those are off, if you have the integrated sedan radio, then you will remove the mounting screws that are under the vertical trim pieces and then the radio will be free. If you do not, pull the radio trim and speedometer trim back as one unit (being careful to not break the tabs that connect the two).
FS: 2011 CD STEREO UNIT (1.5 Months Old - Flawless Condition) Pacquiao Items for Sale by private party 2 07-29-2011 07:44 AM
Everything for an aftermarket stereo (07 Sedan) enve1160 Willing to Buy by private party 0 08-09-2010 08:10 AM
