Old 01-11-2014, 09:04 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
on mine the solenoid is apart from the sliding valve...maybe it wasnt that way to begin with...
however the 07s were not well designed. I wonder if its worth it to buy an 09 -10 if it will fit..
yaris9876 is offline   Reply With Quote
Old 01-11-2014, 09:30 PM   #2
They were the same with the same part number from 06 to present (2014). If yours is separated the most likely cause is someone prying against it while tightening the drive belt.
Yaris 2007, 1KR-FE valves knocking Put-in DIY / Maintenance / Service 2 12-06-2011 04:00 AM
Anyone care to make a DIY on break flushing and bleeding? Hard_Yaris DIY / Maintenance / Service 19 05-04-2011 03:49 PM
Valve's broken. N3misiS DIY / Maintenance / Service 17 11-15-2010 04:35 AM
Fuga de aceite en OCV carlosh Central and South America 4 06-03-2009 12:08 PM
BENT VALVES in the head: tell me how that happens.... BLAZINBLUEVITZ Off-topic / Other Cars / Everything else Discussions 27 02-17-2009 04:49 PM
