Old 01-13-2014, 07:10 AM   #1
waxaddict
Drives: yaris 5 door 2002
OK I'll give it a bump start in a bit.
Am I right in thinking that if it bumps alright then its definitely a battery issue?
waxaddict is offline   Reply With Quote
Old 01-13-2014, 07:21 AM   #2
Yes. Battery or possibly alternator, but if it has been doing more sitting than driving, then it is more likely the battery. Over here, most auto parts stores have a device that they can hook up to the car to test the battery/alternator and will do so for free. If you have access to a multimeter a simple test is to measure the battery voltage before and after starting the vehicle. It will typically run between 11 and 12.5 volts before starting and will go up to 13.6 to 14.1 volts once running.
yaris won't start, engine truns over but won't start. zara616 General Yaris / Vitz Discussion 16 09-05-2021 11:39 AM
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
Yaris starts then it wont start. wush11 General Yaris / Vitz Discussion 18 01-05-2011 11:53 AM
