Old 01-15-2014, 10:16 AM   #1
The filter housing is located right in front of the battery. There are two metal clips that you flip down to and then the other side of the cover is seated into a groove. Once you lift the cover the filter is right there. There is a square corner on the filter, note where that was positioned and orient the new one the same way.
As for part numbers, you can always check the book by the filters in the auto parts or big box store, but off the top of my head the Fram part is CA10190.
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Correct air filter not fitting right in sedan? JerseyJeff84 DIY / Maintenance / Service 13 09-28-2011 02:27 PM
Engine Air Filter Shadowbeast DIY / Maintenance / Service 7 06-16-2010 09:00 PM
