Old 01-15-2014, 11:35 AM   #1
vk2193
Drives: 2008 Toyota Yaris Sedan
ABS and Brake light
Hey guys, i've got the same problem, ABS and Brake light came on on one snowy day... after reading ur comments i took my yaris sedan 2008 to the mechanic, he cleaned the connections and the light came off... i left my mechanic's parking lot and the the lights came on again! i came back he looked at it and said drive for one week look how it goes and if problem is still there come back. i came home and ht lights came off!!! not sure what the problem is, i will try to wash the underbody of the car, i never washed it there before...
vk2193 is offline   Reply With Quote
Old 04-06-2015, 11:02 AM   #2
chrisgblues
Drives: 2007 Toyota Yaris
I had the same problem last year (spring 2014) and after reading this forum I figured the ABS sensor must have had some moisture or corrosion in it. I decided to tackle the problem myself with good results. Be aware that I am NOT a mechanic and I can't even raise my vehicle off the ground, but I managed to get rid of the issue.
I laid down underneath the car with a can of WD-40 and sprayed a LOT of it in the area of the ABS sensors. I did this on all 4 wheels. It's not easy to get in there but I managed to soak all the sensors as much as possible hoping the WD-40 would soak in the small gaps where the contacts are.
It didn't work right away, but probably within a week the ABS light and the brake warning light went off. It came back on for a brief period then went off again. It's been about a year and the light hasn't come back on. I intend to spray it again with WD-40 later this spring for preventive maintenance. This may or may not work for you, but it worked for me. Good luck.
chrisgblues is offline   Reply With Quote
Old 10-24-2015, 10:43 AM   #3
MUSKOKA800
MUSKOKA800's Avatar
Mine also cycled on and off for a long period until I attempted to pull the plug off for inspection and likely doing permanent damage as the light stay on constantly now. Solution = install new rear wheel bearing (with ABS) and possibly also the wiring harness. OR drive with the warning lights on and no ABS.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Trouble putting 3rd brake light after rear speaker install..... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 5 12-05-2008 03:10 AM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
