Old 11-20-2014, 01:50 PM   #1
Hershey
^ I believe that's right for the 175/65-15 . The Prius C is the same as the Honda Fit base and Yaris as you stated . Not a big selection for variety . ^
Old 01-07-2015, 12:30 PM   #2
adf_604
adf_604's Avatar
Drives: 2003 Echo Sedan, Silver
New pair of all-seasons
I have never bought a dedicated summer tire, mainly as it doesn't seem cost effective in a rainy region. I usually go for the all-season workhorse type tire and yesterday bought 2 new Kelly Explorer Plus for the front axle on my Echo.
The tread is fairly deep and blocky (almost like a winter tire) which I'm hoping equates to good all-weather grip. Already they are a vast improvement from my previous pair which were on the car when I bought it, and broke free in the wet with the slightest press of the gas pedal.
http://www.tirebuyer.com/tires/kelly...7#.VK1s7ZiDq1w
adf_604 is offline   Reply With Quote
Old 12-08-2014, 02:31 PM   #3
Hershey
The RT43 T + H are a 1 ply sidewall . Not sure for the V .
Old 01-07-2015, 11:40 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
^^^ For your safety, always put new tyres on the rear... even on front wheel drive vehicles.
Old 01-08-2015, 08:01 PM   #5
adf_604
adf_604's Avatar
^^You don't work in a tire shop do you?
Thanks for the advice, but I respectfully decline. Yes, I am aware of this "rule" and yes, I have read and understand the reasoning behind this, however it seems to me that this is outdated thinking from the time of heavy, RWD cars. On another note, that form of thinking seems to imply that your tires should never be rotated, as at some point you will have two tires with deeper tread on the front axle, which apparently is unsafe.
My rear tires still have plenty of tread also.
Again, I appreciate the advice and understand the reasoning, but my personal preference is to have my grippier tires on the front axle. I needed better traction, and would not have gotten this better traction by leaving the offending tires on the front.
Cheers!
Old 01-08-2015, 08:57 PM   #6
nortonfb
Drives: 2007
The logic is in case of a blow out, it's easier to correct the front as opposed to the rear.
Norton
nortonfb is offline   Reply With Quote
Old 01-09-2015, 01:19 AM   #7
kimona
kimona's Avatar
In an emergency situation, you will have a better chance of controlling the car when the best rubber is on the rear... regardless rear or front wheel drive.
And, yes... I never rotate my tyres.
Old 01-09-2015, 08:35 AM   #8
nortonfb
Drives: 2007
I don't know, but that is what I was taught.
Never had the problem, hope I never do.
Norton
Old 01-09-2015, 11:31 AM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
Norton
It's just because it's the rear tires that do all the work stopping your car. Otherwise, you would lost control each time you brake and the rear locks up. Obviously it depends how you drive.
Best is just rotate the tires and buy 4 new when they are finished, since tires do expire when they dry rot.
Old 01-09-2015, 12:04 PM   #10
nortonfb
Drives: 2007
The rear brakes do very little in stopping. They are anchors and not very efficient ones. As you apply brakes, inertia drives the weight into the front suspension which causes it to compress (front end dive). Ever ridden a bike or motorcycle? Your most efficient braking is with the front.
At the MSF and other bike courses you are taught to apply the rear only after applying the front to avoid the dreaded rear wheel slide.
If you have any doubts; why do you think rear brakes are replaced so infrequently?
Norton
Old 01-09-2015, 12:17 PM   #11
roxy1
Drives: 2014 yaris 5 speed
additionally, when you brake you have some control over the direction of the front tires. not so of the back tires. if the tread is poorer back there it may cause the rear to slide out leading to an undesirable loss of control.
roxy1 is offline   Reply With Quote
Old 01-09-2015, 04:08 PM   #12
kimona
kimona's Avatar
Where to Install New Pairs of Tires?
I found this on Tire Rack:
http://www.tirerack.com/tires/tirete...jsp?techid=52&
Old 01-09-2015, 05:53 PM   #13
roxy1
forget that. I just drove to the headquarters today and replaced my sh*t oem tires.
General Altimax RT43. $347 installed and for sure the best all season tire ive ever used in snow. I drove home on icy, snowy roads, some unplowed with 6+ inches still sitting on them. on the one stretch of dry pavement on the toll road, it was also clear that much of the road noise that no longer intrudes into the car was from the oem tires.
for anyone looking for all season tires in the oem size for the 3rd gen yaris (175/65-15) id say the ratings this tire gets on tire rack are legit.
Old 01-09-2015, 06:03 PM   #14
nortonfb
Drives: 2007
You must be near Ohio or Indiana. No toll roads in Michigan.
Snow up here, is not very deep, few inches at most.
Norton
Old 01-09-2015, 06:10 PM   #15
roxy1
Norton
southwest MI, near Niles. Lake effect snow is not our friend.
Old 01-09-2015, 08:21 PM   #16
kimona
kimona's Avatar
I've read a lot of very positive reviews for the General RT43.
Old 02-15-2015, 10:36 PM   #17
nookandcrannycar
my sh*t oem tires.
I agree. They s**k.
Good to know!
Old 01-09-2015, 07:38 PM   #18
IllusionX
Yeah. This also applies if you must only get 2 winter tires. Winters should go in the rear.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Selling winter tires and low profile floor jack with 2 stands voodoo22 Canada 10 11-16-2009 09:12 PM
NEED USED TIRES!!! natethegreat38 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-06-2008 12:11 AM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
