Old 01-15-2014, 09:54 PM   #1
spiceyhotwings
Drives: 2009 Yaris RS 5 door
The indicator is fed directly off the bulb circuit, so it makes sense that both do not work. The most likely point of fryulation is the bulb connector. start with checking that.
So, they do look fried..the left side connector is more brown than the right side connector.
How do I replace one or both connectors?
my new 2009 Yaris RS 5 door
spiceyhotwings is offline   Reply With Quote
Old 01-15-2014, 10:56 PM   #2
You can buy them from most auto parts stores. Some even stock ceramic ones, which are more heat tolerant. Typically they come with about 6" of wire, so you cut and splice them into the existing harness.
Old 01-15-2014, 11:20 PM   #3
nookandcrannycar
I agree with Schroomster (post #5), but I still can't help but chuckle just a bit pondering the thought of 'dark mountain roads' (the OP in PA) in Florida, where the highest point would be considered 'a hill' in many states .
Low Beams not working Karri'es Yaris DIY / Maintenance / Service 7 02-10-2012 08:34 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
