Old 01-17-2014, 02:46 PM   #1
JustPassinThru
Drives: No more Yaris
The patch-cord jack is in the glove-box...it's in the frame to the glove-box door, at the top.
You have to get a patch-cord that has an angled-off jack, so you can close it.
It's a much-poorer design than the 2009 which had the jack socket in the console.
JustPassinThru is offline   Reply With Quote
Old 01-17-2014, 04:07 PM   #2
The O.P.'s 2012 Sedan is not the same as your 2012 liftback.
The OEM ipod connectivity kit is just for Apple devices (and has the 29 pin connector, so if you have one with the lightening connector you would need to use the adapter).
Can you post a pic of what your headunit looks like? If it is the one I am thinking it is, then your other option is to add an AUX jack (which theoretically the wiring should be present for) which give you a 1/8" headphone jack input, so you can use a male to male cable to connect any device with a headphone jack.
2012 Yaris Sedan Dorkinheimer Third Gen Yaris General Discussion 34 03-31-2013 06:37 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
