Old 01-20-2014, 04:39 PM   #1
UnseenK
Drives: Yaris '09 White Sedan
It seems like every battery I get this happens to, it never happens to the other 3 cars at my house. Is this just a common issue with our cars, or just a common issue with mine? I live in a hot climate as well, not sure if that plays into it at all.
UnseenK is offline   Reply With Quote
Old 01-20-2014, 04:56 PM   #2
I haven't seen corrosion on any of my Yaris. It may be the fact that you are purchasing non-sealed liquid electrolyte batteries, which are more prone to boiling over in hot climates. It also may not be a bad idea to have your alternator tested to verify that its internal voltage regulator is working properly. If it is putting out too high of a voltage (over 14.1 volts) it may be causing the batteries to boil over as well.
Battery keeps going dead Outdoorsman In Car Entertainment + Electronics (audio / video / alarm) 6 09-09-2013 04:43 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Battery discharge omega3126 DIY / Maintenance / Service 0 05-19-2010 12:00 PM
