Old 01-22-2014, 04:41 AM   #1
Originally Posted by freewave View Post
I did double check the plugs, and they came pre-gapped to the correct distance. I double checked the gap as well before putting them in.
What I didn't do, but have seen suggested now that I'm doing my panic research, is unplug the battery for a minute to "refresh" the firing rate after changing the plugs. For some reason it wasn't in any walk through I found but it was in the troubleshooting guide. :P
Any idea how to check the torque converter? Or is it a straight replacement and hope that's the issue?
Thanks!
Typically resetting the ECM is not necessary with plug replacement, but you can try doing so by disconnecting the battery for a minute. You can also try cleaning the throttle body and MAF sensor.
For testing the torque converter, the thing that would fail with it causing stalling on start is the one-way-clutch within it. Testing that requires pulling the torque converter out of the tranny.
Old 01-22-2014, 10:12 AM   #2
freewave
Drives: 2007 Toyota Yaris
I will check into cleaning the throttle body and MAF sensor today. I'm not sure about the torque converter though - its not stalling on start, its stalling when I pass through neutral into drive (unless I feather the gas when shifting) or back through neutral into reverse or park.
I showed it to a former mechanic coworker and he thinks it sounds electronic. There are no sounds to indicate an issue, the motor just dies. Like it does't know how high to idle in neutral so it shuts off.
freewave is offline   Reply With Quote
Old 01-22-2014, 10:22 AM   #3
So, once you get past neutral in either direction it is fine?
Old 01-22-2014, 11:28 AM   #4
freewave
Exactly. I can feather the gas to get past neutral without stalling. That works in both directions (reverse to drive, and drive to reverse) however its awkward to do when going from drive to reverse. I am currently just letting it stall when I park.
Old 01-22-2014, 11:34 AM   #5
OK. For that behavior the service manual points to the ECM, shift lock ECU (lives inside of the shifter) or the Park/Neutral switch (the switch that the shifter cable moves on the tranny) being the culprit. Diagnosis would best be done with the Toyota TechStream tool, as the data that it shows would allow one to narrow the problem down to one of those three devices.
Old 01-22-2014, 01:41 PM   #6
freewave
I'm going to test the Park/Neutral safety switch myself in about an hour. From what I read, you can test by starting the vehicle, then unplugging the switch. From there I would see if the car stalls in neutral. If it doesn't, then I clean or replace the switch. Otherwise I move on to the next part.
Old 01-22-2014, 02:37 PM   #7
That will work for testing the park/neutral switch. There's a voltage test that can be done for the shift lock ECU as well.
plug, shift, spark, stall, transmission
Stupid Thing I did while working on my Yaris Today fnkngrv DIY / Maintenance / Service 5 10-19-2012 12:08 AM
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
