Originally Posted by freewave
I will check into cleaning the throttle body and MAF sensor today. I'm not sure about the torque converter though - its not stalling on start, its stalling when I pass through neutral into drive (unless I feather the gas when shifting) or back through neutral into reverse or park.
I showed it to a former mechanic coworker and he thinks it sounds electronic. There are no sounds to indicate an issue, the motor just dies. Like it does't know how high to idle in neutral so it shuts off.
So, once you get past neutral in either direction it is fine?
