Old 01-22-2014, 01:41 PM   #9
freewave
Drives: 2007 Toyota Yaris
OK. For that behavior the service manual points to the ECM, shift lock ECU (lives inside of the shifter) or the Park/Neutral switch (the switch that the shifter cable moves on the tranny) being the culprit. Diagnosis would best be done with the Toyota TechStream tool, as the data that it shows would allow one to narrow the problem down to one of those three devices.
I'm going to test the Park/Neutral safety switch myself in about an hour. From what I read, you can test by starting the vehicle, then unplugging the switch. From there I would see if the car stalls in neutral. If it doesn't, then I clean or replace the switch. Otherwise I move on to the next part.
freewave is offline   Reply With Quote
Tags
plug, shift, spark, stall, transmission
Stupid Thing I did while working on my Yaris Today fnkngrv DIY / Maintenance / Service 5 10-19-2012 12:08 AM
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
