![]() ![]() Drives: yaris advance Join Date: Jan 2009
2008, sedan, manual
OK. The back-up light switch is located on the top of the tranny. You will need to move the battery out of the way to get at it.
To do a quick and easy test to see if it is actually the problem, you could jump the red wire in pin 3 of connector CA1 to a +12V power source. If the lights come on when you do that, then you know that either the back-up switch is bad or its connector is corroded. CA1 - MT Back-up Switch.jpg
#3 | |
![]() ![]() Drives: 07 Yaris Join Date: Sep 2012
What exactly is the bottom end of the arrow pointing to? I can't quite tell from the diagram. Also should this be done with the car on or off, or in accessory mode? Thanks |
#4 | |
| Question about lights | kaymm | General Yaris / Vitz Discussion | 4 | 04-20-2020 09:10 PM |
| No parking lights | ryufrank | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-06-2013 09:28 AM |
| Clazzio MicroImage problems please help | boggydee | Cosmetic Modifications (Exterior/Interior) | 1 | 08-24-2012 04:16 AM |
| LED tail lights installed | Cutie Pie #2 | Cosmetic Modifications (Exterior/Interior) | 10 | 08-20-2012 11:25 PM |
| JUST GOT MY JDM TAIL LIGHTS!!!!! | falkor_99 | Cosmetic Modifications (Exterior/Interior) | 12 | 10-01-2007 11:25 AM |
