Old 01-25-2014, 08:43 AM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
rims
Hi CT, thanks for the rim info and the offer to buy your rims. My next move is to remove my rims and see for sure what size Im running. Having a mean winter here in upstate NY so just maybe I'll get to the rims sometime this spring when it warms up. But just for the sake of argument, what were you asking for your rims? (4) Thanks P And what size info is stamped on the rims?
peewee1 is offline   Reply With Quote
Old 01-25-2014, 09:46 AM   #2
If you have the 5 spoke S rims, then the spec on them is: 15x5.5" ET45 (as I happen to have a set of them that I run on one of mine).
The steel wheels that I have on hand are OEM 15x5.5" +45 as well. I am looking for $125 for the set + shipping.
Old 01-26-2014, 05:51 AM   #3
peewee1
PEEWEE1
peewee1's Avatar
rims
CT, do the rims have the TPMS? Also any idea what shipping cost would be? Any pictures of the rims that I can look at? (oem's)
Old 01-26-2014, 08:36 AM   #4
Below is a picture of the 4 rims. They do not include stems, but I do have a set of OEM TPMS sensors that I could do $100 for the set. Shipping to upstate NY would be $41.
Old 01-26-2014, 10:10 AM   #5
peewee1
PEEWEE1
peewee1's Avatar
rims
CT, is the $41 shipping for a single tire or all four? Also not to sound to stupid but the lower 2 rims look some what bent or distorted. Is this some kind of optical thing going on? Other wise the rims look great. Can I run rims without TPMS?
Old 01-26-2014, 10:31 AM   #6
$41 shipping would be for the whole set.
The distortion is just due to the angle of my phone when I snapped the picture. They are all in great shape.
You can run without the sensors. If you do, the warning light will come on. You can bypass it though if it is annoying. Also, running with a second set of sensors will require having the TPMS ECU reprogrammed when you switch back and forth, as the Yaris only remembers one set. The reprogramming can done by the dealer or a tire shop.
Check out my thread below for instructions on how to install a switch to enable/disable the TPMS light:
http://www.yarisworld.com/forums/showthread.php?t=11058
Old 01-26-2014, 10:44 AM   #7
peewee1
PEEWEE1
peewee1's Avatar
rims
CT, I'll take the rims, what next?
Does increasing rim size affect the acceleration? Jack Yak Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 10-17-2011 01:25 PM
How do you know what size rim and tire to purchase? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 23 06-17-2010 05:02 PM
Rim sizing - what size to get for OE equivalent? jay Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 11-20-2006 03:25 PM
Rim size difference???? marcus General Yaris / Vitz Discussion 2 11-03-2006 03:20 PM
