Old 01-29-2014, 08:55 PM   #1
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Mine pops up quite frequently. Its easy enough to re-attach as I've done it several times now, but I will go to switch it over a few weeks later, and there is a lot of resistance -- and then you feel it pop off again. Not sure whats up.. but my inside windows are fogging up like crazy every single day lately even with it on 'fresh air' and I put the AC button down, so not sure if the 2 problems are related.
white_rice is offline   Reply With Quote
Old 01-29-2014, 09:51 PM   #2
When the guy filed down the tabs to make then fit in the wrong order he probably damaged the clips that hold the cable end to the knob.
The fogging issue may be because the condensate drain is plugged.
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 09:47 AM
