Old 01-30-2014, 03:33 PM   #1
If I am seeing that correctly, the "bypass" connection really doesn't do anything as wired.
You will need to connect the yellow "starter" wire of the remote starter directly to both the black starter wires on the ignition switch connector and to the black wire on the clutch switch.
Old 01-30-2014, 11:03 PM   #2
racefear
Drives: yaris 2006
Did you mean purple `starter' wire of the prostart remote starter ?
Seems to be clear for you... I updated post 202(Relay part), can you take a look please, mod the pic, this can help me and futur user...
Some guys use 1N4004 diode betwen 85 - 86 for protection, usefull ?
Tanks for your time
racefear is offline   Reply With Quote
Old 01-30-2014, 11:10 PM   #3
Tanks for your time
Correct on the purple. The diagram corrections that you made are good now.
The diode won't hurt anything, but in this case where you are only switching power to another relay coil, it really is not necessary.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
