Originally Posted by CTScott
If I am seeing that correctly, the "bypass" connection really doesn't do anything as wired.
You will need to connect the yellow "starter" wire of the remote starter directly to both the black starter wires on the ignition switch connector and to the black wire on the clutch switch.
Did you mean
purple `starter' wire of the prostart remote starter ?
Seems to be clear for you... I updated post 202(Relay part), can you take a look please, mod the pic, this can help me and futur user...
Some guys use 1N4004 diode betwen 85 - 86 for protection, usefull ?
Tanks for your time
