Old 02-04-2014, 10:59 AM   #1
Rutherford
Drives: 2008 Yaris
Bought me a used evap canister and installed it. Thanks so much for the help with the connections. Was not difficult once I know how to get them apart. After about 180 miles my check engine light came on and I went by Advanced Auto to see what code had come up. It read a small evap leak. I may not have had the gas cap on all the way locked so I cleared the code and have driven it now about 250 miles without the check engine light coming on. I still have a problem though. I cannot pump gas very fast when I fill it up. It seems like it is not able to relieve the air as quick as I am putting the gas in. When I took the old evap canister off I checked the filter box? in the line from the evap canister to the filler neck. I did not remove it but I disconnected both lines leading into it and attached some tubing so I could blow through from each direction to make sure there was no water in it. I shook it and did not hear anything. Did not see any moisture but it seemed like there was some restriction in it. I figure it may only pass air/fumes in one direction but it was difficult to get air through either way. Could this cause the problem with not being able to pump gas at a normal rate or may I still have an issue with the evap canister? It did pass the emission test here in NC when the light was off
Rutherford is offline   Reply With Quote
Reliable Source for Replacement Parts wagon DIY / Maintenance / Service 4 03-06-2013 12:56 PM
Shock and Struts Replacement... New Tires Blowtorch DIY / Maintenance / Service 3 07-25-2012 12:44 PM
EVAP canister Jason@SportsCar Items for Sale by private party 5 04-11-2012 01:04 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
