Old 02-06-2014, 12:42 PM   #1
There are very many. For the US market alone there are over 20 separate part numbers. The variations for our market include different features (ABS, traction control, transmission type) and regional differences (US, Canada, Puerto Rico and Mexico specific ECMs).
Old 02-07-2014, 10:52 AM   #2
japle
japle's Avatar
Drives: Vitz S 2007 LB
If there are that many, which ones are tuneable? Which ones are the best for our cars? My country uses ron 95 and 97 for petrol, so i will need a rechipable ecu, but my guy says mine is not programable.
Either i get one new chipable ecu, or i have to rely on emanage. Which i have no idea what can emanage control
japle is offline   Reply With Quote
Old 02-07-2014, 11:25 AM   #3
None are tuneable oe programmable at this point, as Toyota is very secretive with their ECM programming. The best one for your car is the one that goes with your car, as using one from a different area will typically result in problems, as for example, if you put a US market one in your car the check engine light would always be on, because your car does not have the same evaporative emissions system as ours does.
Old 03-13-2017, 07:45 PM   #4
Majoto2
Drives: 2012 Red 3 Door Hatch Manual
Swapping ECM in America?
2012 Yaris 3D hatchback manual.
Is is possible to swap out my Japanese ECM for an American/Canadian/Puerto Rican one so I it will then have cruise control in the ECM? I bought the car in America and it has a J (for japan) on the first slot of the VIN, I am assuming that the computer was built in japan and doesn't have these features built in.
But it makes sense in my head that if I found a manual ECM programmed in America then it would swap over without a hitch.
Can you help?
Majoto2 is offline   Reply With Quote
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 04:47 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 06:15 PM
