Old 02-08-2014, 03:08 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I also did this mod and recommend it for sure. I had to modify the OEM hose slightly by removing a very thin layer of rubber with a dremel. No biggie and worked like a charm and did a coolant bypass with a copper joint.
I also have a high idle for around 60 min or so. I've had it that way for many years and I've had zero problems, FWIW.
@HANZO_187: There's a couple of very good threads about this info. Just keep in mind that some 1zz tb's work without having to swap chips (located at the base), while others apparently require it. I did it in about 10 min (maybe less) by using a drill with a very narrow bit (so that it only destroys the rivets and nothing else). HTH
you mean 60 seconds right?
As far as the hose go, you can use the hoses that are on the car, just swap them around. Make sure you have a pan under the car to catch the coolant when you pull the hoses off. you can use a used spark plug to plug the hose when you disconnect them from the throttle body and try to be fast. If your not fast enough, its going to get messy.. lol, but its not a big deal at all. I just zip tied them together to keep them away from the shifter cables
Now, on the stock manifold, I measured the rubber "O" ring on the mani-throttle body. I did not have to make a gasket. The 1zz throttle body fit just right where it sealed up with the throttle body. It was close, but I did not have an issue with any leaks. I used the existing O ring on the manifold.
-Derrick-
Old 02-08-2014, 01:26 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yes, yes I do.
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
Installed the 1zz throttle body - AlexNet0 DIY / Maintenance / Service 135 08-01-2014 07:57 AM
FS: 1ZZ throttle body and Fujita intake mrbond Items for Sale by private party 25 09-08-2009 10:21 PM
Intake to match the 1ZZ throttle body fuji DIY / Maintenance / Service 2 06-17-2009 10:02 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
