Congradulations on selecting the 3 door hatch with manual transmission! The most versatile and cost effective car on the market IMHO! The two doors make entry and gettings things in and out of the car easy. The MT gets better gas mileage and will last forever even without oil changes.
I have driven my 3 door to Alaska and back (10,400 miles in 16 days) in perfect comfort and I was 55 years old then. Sounds like you are in an excellent position the learn with your mechanic friend and the resources here CT Scott is an outstanding font of knowledge about all things Yaris! ![]() My advice is to switch to regular oil next time and a less expensive oil filter like a FRAM or purolator. Saves quite a bit of money. Synthetic oil was developed for turbine engines with very high operating temps. It IS good if it gets really cold where you live (0 degrees F) to help starting.
#2 | |
![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
#3 | |
Buy your torque wrench here: www.harbourfreight.com
#4 | |
.http://www.harborfreight.com/1-4-qua...ench-2696.html http://www.harborfreight.com/1-2-hal...rench-239.html I'm assuming I should get the 1/2 for more leverage 18in vs 11in? |
#5 | |
I am happy with ALL my HF purchases. Although I note prices are going UP! I think you are right the 1/2 inch driver is the way to go. However... I feel obligated to point out its not really necessary to use a torque wrench on your wheels. I use the one that comes with the car with a cheater 1 1/2 inch PVC white plastic water pipe about 18 inches long. I guess I torque them to about 25 ft lbs I am crippled and if in an emergency had to r and r a wheel wouldnt be able to do ones t'd to 80 ft lbs. Maybe mag wheels need TR's?
#6 | |
Edit ------ I bought the socket, but it says impact socket. I didn't do any research as I remembered about while in store and I'm not sure if it's ok to use on the torque wrench. It does fit. Last edited by vaironl; 02-08-2014 at 08:50 PM. Reason: Adding information |
![]() ![]() Drives: 2008 Hatch Red Join Date: Apr 2012
An impact socket is heavy duty so it will not break with an impact wrench. As long as it fits you are fine.
#8 | |
Its just more convient to use the supplied wrench with a cheater for road duty.
#9 | ||
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| Dealer oil change | boggydee | DIY / Maintenance / Service | 16 | 06-30-2010 11:21 PM |
| First DIY oil change but... | derickveliz2 | DIY / Maintenance / Service | 31 | 02-02-2009 11:36 AM |
| About to do my first oil change | Kaotic Lazagna | DIY / Maintenance / Service | 32 | 01-15-2007 04:00 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
