Old 02-08-2014, 12:23 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Congradulations on selecting the 3 door hatch with manual transmission! The most versatile and cost effective car on the market IMHO! The two doors make entry and gettings things in and out of the car easy. The MT gets better gas mileage and will last forever even without oil changes.
I have driven my 3 door to Alaska and back (10,400 miles in 16 days) in perfect comfort and I was 55 years old then.
Sounds like you are in an excellent position the learn with your mechanic friend and the resources here CT Scott is an outstanding font of knowledge about all things Yaris!
My advice is to switch to regular oil next time and a less expensive oil filter like a FRAM or purolator. Saves quite a bit of money. Synthetic oil was developed for turbine engines with very high operating temps. It IS good if it gets really cold where you live (0 degrees F) to help starting.
Yeah I noticed that a bit late, it has gotten pretty close to 0 in the past month. I'm gonna buy a torque wrench soon since I have to take the wheels off but I'm not sure of where to get it from. Mixed reviews on amazon.
vaironl is offline   Reply With Quote
Old 02-08-2014, 04:11 PM   #2
bronsin
bronsin's Avatar
Cold temps arent a long term issue in VA but zero degrees is zero degrees I guess.
Buy your torque wrench here:
www.harbourfreight.com
Old 02-08-2014, 04:28 PM   #3
vaironl
vaironl's Avatar
I was just checking out their deals earlier. Read a couple of people say they have some good products and some bad products, well every store does. Since you pointed them out I'll swing by the store today. They also have free coupons for some items .
http://www.harborfreight.com/1-4-qua...ench-2696.html
http://www.harborfreight.com/1-2-hal...rench-239.html
I'm assuming I should get the 1/2 for more leverage 18in vs 11in?
Old 02-08-2014, 06:19 PM   #4
bronsin
bronsin's Avatar
Harbour Freight the BEST STORE IN THE WORLD if you are a man!
I am happy with ALL my HF purchases. Although I note prices are going UP!
I think you are right the 1/2 inch driver is the way to go.
However...
I feel obligated to point out its not really necessary to use a torque wrench on your wheels. I use the one that comes with the car with a cheater 1 1/2 inch PVC white plastic water pipe about 18 inches long. I guess I torque them to about 25 ft lbs I am crippled and if in an emergency had to r and r a wheel wouldnt be able to do ones t'd to 80 ft lbs.
Maybe mag wheels need TR's?
Old 02-08-2014, 08:30 PM   #5
vaironl
vaironl's Avatar
However...
Just came back from HF. I got the torque wrench, then I saw the 21mm socket, then I remembered I needed a tire air pressure gauge, and then I saw towels to clean my hands after dealing with oily stuff and I finally remembered about a coupon for a free power outlet. Why does this happen?
Edit
I bought the socket, but it says impact socket. I didn't do any research as I remembered about while in store and I'm not sure if it's ok to use on the torque wrench. It does fit.
Old 02-08-2014, 09:28 PM   #6
andulong
andulong's Avatar
Drives: 2008 Hatch Red
An impact socket is heavy duty so it will not break with an impact wrench. As long as it fits you are fine.
andulong is offline   Reply With Quote
Old 02-09-2014, 07:53 AM   #7
bronsin
bronsin's Avatar
It will be fine. Ive seen that exact socket in HF. I bought an entire metric set of impact sockets and have used the 21mm on breaker bars.
Its just more convient to use the supplied wrench with a cheater for road duty.
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
Dealer oil change boggydee DIY / Maintenance / Service 16 06-30-2010 11:21 PM
First DIY oil change but... derickveliz2 DIY / Maintenance / Service 31 02-02-2009 11:36 AM
About to do my first oil change Kaotic Lazagna DIY / Maintenance / Service 32 01-15-2007 04:00 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
