#1 | |
Buy your torque wrench here: www.harbourfreight.com
#2 | |
![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
.http://www.harborfreight.com/1-4-qua...ench-2696.html http://www.harborfreight.com/1-2-hal...rench-239.html I'm assuming I should get the 1/2 for more leverage 18in vs 11in? |
#3 | |
I am happy with ALL my HF purchases. Although I note prices are going UP! I think you are right the 1/2 inch driver is the way to go. However... I feel obligated to point out its not really necessary to use a torque wrench on your wheels. I use the one that comes with the car with a cheater 1 1/2 inch PVC white plastic water pipe about 18 inches long. I guess I torque them to about 25 ft lbs I am crippled and if in an emergency had to r and r a wheel wouldnt be able to do ones t'd to 80 ft lbs. Maybe mag wheels need TR's?
#4 | |
Edit ------ I bought the socket, but it says impact socket. I didn't do any research as I remembered about while in store and I'm not sure if it's ok to use on the torque wrench. It does fit. Last edited by vaironl; 02-08-2014 at 08:50 PM. Reason: Adding information |
![]() ![]() Drives: 2008 Hatch Red Join Date: Apr 2012
An impact socket is heavy duty so it will not break with an impact wrench. As long as it fits you are fine.
#6 | |
Its just more convient to use the supplied wrench with a cheater for road duty.
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 04:25 PM |
| Dealer oil change | boggydee | DIY / Maintenance / Service | 16 | 06-30-2010 11:21 PM |
| First DIY oil change but... | derickveliz2 | DIY / Maintenance / Service | 31 | 02-02-2009 11:36 AM |
| About to do my first oil change | Kaotic Lazagna | DIY / Maintenance / Service | 32 | 01-15-2007 04:00 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
